This plugin lets you integrate your project in Android Studio with Crowdin. Upload new source strings and existing translations to the system instantly as well as download translations from your Crowdin project.
project-id=your-project-id
api-token=personal-access-token
The plugin will automatically find strings.xml
file in the values directory, and if updated, the changes will be uploaded to Crowdin instantly. If you have more source files or the source file name differs from the default strings.xml
, specify it in the sources
parameter.
sources=file1.xml, file2.xml
By default, translations are exported to the Resources
folder (**/resources/values-uk/strings.xml, **/resources/values-fr/strings.xml, …)
To set up your own source and translation pattern, use the following configuration in the crowdin.properties
file:
files.source=/values/*.xml
files.translation=/values-%android_code%/%original_file_name%
files.1.source=/another/path/*.xml
files.1.translation=/another/path-%android_code%/%original_file_name%
Read more about the Placeholders to put the appropriate variables.
%original_path%
placeholder is not supported.For Android Studio projects that use a git VCS, the plugin will automatically create corresponding branches in Crowdin. If you do not use branches feature in Crowdin, add disable-branches=true
parameter into the configuration file.
Add auto-upload=false
to prevent automatic file upload to Crowdin.
auto-upload=false
To upload source files to Crowdin manually, use the menu Tools > Crowdin > Upload Sources
or click the right mouse button on the file and select Upload to Crowdin
To upload existing translations, use the menu Tools > Crowdin > Upload Translations
To download translations from Crowdin, use the menu Tools > Crowdin > Download Translations
