Modal Module
The module allows the creation of a new modal dialog. The current module works only with the Context menu module that opens it.
Modal module structure:
  "modal": [
      "key": "your-module-key",
      "name": "Module name",
      "url": "/module-url"
Properties:
key
Type: string
Required: yes
Description: Module identifier within the Crowdin app.
name
Type: string
Required: yes
Description: The human-readable name of the module. Uses as Context menu text
url
Type: string
Required: yes
Description: The relative URL to the content page of the module that will be integrated into the UI.
environments
Type: string
Allowed values: crowdin, crowdin-enterprise
Description: Define the environment in which the module will run.
This parameter is needed for cross-product applications.
Was this article helpful?
