Understanding Scopes
Scopes let you set the exact access type you need. Scopes limit access for the personal access tokens, OAuth tokens, and Crowdin apps. They don’t provide any additional permissions except those the user already has.
The scopes you specify for the OAuth app on Crowdin will be shown to the users on the authorization form.
Available scopes
Name Key Description
All scopes all Grants access to perform any of the following actions.
Notifications notification Grants access to the list of enabled notifications, the ability to subscribe to a channel, as well as unsubscribe from it.
Translation memories tm Grants access to manage project Translation Memory files.
Machine translation engines mt Grants access to get the list of Machine Translation engines connected, as well as to create, delete MT engines, and update their settings.
Vendors vendor Crowdin Enterprise only. Grants access to get the list of Vendors.
Glossaries glossary Grants access to manage the files with the project terminology.
Teams team Crowdin Enterprise only. Grants access to teams of users.
Groups group Crowdin Enterprise only. Grants access to manage project groups a user has access to.
Projects project Grants access to manage project a user has access to.
Tasks project.task Grants access to task lists, permission to create, delete, and update project tasks.
Reports project.report Grants access to reports list, permission to generate, and export project reports.
Translation status project.status Grants access to translation status for the projects: current translation issues, translation progress on different levels: file, language, branch, directory.
Source files & strings project.source Grants access to add, get, delete, and update project branches, directories, source files, and source strings, as well ass access to the file revisions.
Webhooks project.webhook Grants access to read or write hook configurations on repositories a user manages.
Translations project.translation Grants access to add new and manage existing translations.
Screenshots project.screenshot Grants access to get screenshots list, add, get, replace, and delete screenshots, ability to access and modify screenshot tags.
Was this article helpful?
