UI is an essential part of any application. Appealing looks and a well-thought-out intuitive interface will make your Crowdin App more user-friendly and thus attract the audience to use it.
We recommend using frameworks to make your app look good and blend in with Crowdin UI.
Below you can check out a short list of the frameworks you can use for your Crowdin App. Though, you can use any framework for your UI development. This list carries only an informative purpose.
