Context Menu Module
The module allows creating the item in the context menu where possible.
Crowdin context menus:
  • Resources > TM > TM record
  • Resources > Glossary > Glossary record
  • Project home tab > Language record
  • Project > Content > Files > File record
  • Project > Content > Screenshots > Screenshot record
  • Project > Language page > File record
Crowdin Enterprise context menus:
  • Workspace > TM > TM record
  • Workspace > Glossary > Glossary record
  • Project home page > Language record
  • Project home page > Language page > File record
A context menu item can open a specified app module with additional context related to the selected record or custom URL. There are the following types of actions:
  • Open the specified app module in a modal dialog (see Modal module)
  • Redirect to the specified app module
  • Open custom URL in new tab
This module is available to all authorized users.
Context menu item shows the specified module in the modal.
    "identifier": "application-identifier",
    "name": "New Cool App",
    "logo": "/app-logo.png",
    "baseUrl": "https://app.example.com",
    "authentication": {
        "type": "none"
    "scopes": [],
    "modules": {
        "project-integrations": [
                "key": "integration-module-key",
                "name": "New Integration",
                "logo": "/integration-logo.png",
                "url": "/path/to/integration/module"
        "context-menu": [
                "key": "context-menu-key",
                "name": "Name of Context Menu Item",
                "description": "Description of Context Menu Item",
                "options": {
                    "location": "source_file",
                    "type": "modal",
                    "module": {
                        "project-integrations": "integration-module-key"
Redirect
Context menu item redirects to the specified module.
    "authentication": {
        "type": "none"
    "scopes": [],
    "modules": {
        "context-menu": [
                "options": {
                    "type": "redirect",
                    "module": {
New Tab
Context menu item opens a new tab with the URL: baseUrl/options.url.
    "authentication": {
        "type": "none"
    "scopes": [],
    "modules": {
        "context-menu": [
                "options": {
                    "type": "new_tab",
                    "url": "/example/path"
Properties
key
Type: string
Required: yes
Description: Module identifier within the Crowdin app.
name
Type: string
Required: yes
Description: The human-readable name of the module. Uses as Context menu text
description
Type: string
Description: A human-readable description of what the module does.
The description will be visible in the Crowdin UI.
options.location
Type: string
Required: yes
Allowed values: tm, glossary, language, screenshot, source_file, translated_file
Description: The location in UI where the context menu can be added.
options.type
Type: string
Required: yes
Allowed values: modal, new_tab, redirect
Description: The type of action this module will perform.
options.url
Type: string
Use it only with new_tab type
Description: Relative URL.
environments
Type: string
Allowed values: crowdin, crowdin-enterprise
Description: Set of environments where a module could be installed.
This parameter is needed for cross-product applications.
Was this article helpful?
